Configure RIPng Custom Values
Configure custom values for RIPng parameters to replace default values.
Configure RIPng and enable it globally.
Configure custom values for RIPng.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#router rip Switch:1(config-rip)#ipv6 default-information metric 1 Switch:1(config-rip)#ipv6 default-information enable Switch:1(config-rip)#ipv6 timers basic update 30 Switch:1(config-rip)#ipv6 timers basic timeout 180 Switch:1(config-rip)#ipv6 timers basic holddown 120 Switch:1(config-rip)#router rip ipv6-enable Switch:1(config)#show ipv6 rip ================================================================================ RIPng Global - GlobalRouter ================================================================================ Rip : Enabled HoldDown Time : 120 Timeout Interval : 180 Update Time : 30 Default Info Metric : 1 Default Info State : Enabled Default Import Metric : 1
Variable definitions
Use the data in the following table to use the ipv6 rip poison, ipv6 default-information and ipv6 timers basic commands.
Variable |
Value |
<1-4059> |
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. This variable applies only to VLAN interfaces, not ports. |
port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
poison enable |
Enables Poison Reverse. If you disable Poison Reverse (no poison enable). Split Horizon is enabled. By default, Split Horizon is enabled. If you enable Split Horizon, the interface does not advertise IP routes learned from an immediate neighbor back to the neighbor. If you enable Poison Reverse, the RIP updates sent to a neighbor from which a route is learned are poisoned with a metric of 16. Therefore, the receiver neighbor ignores this route because the metric 16 indicates infinite hops in the network These mechanisms prevent routing loops. |
<1-15 Cost> |
Configures the RIPng cost for this port (link). |
holddown <0-360> |
Configures the RIPng holddown timer value, the length of time (in seconds) that RIPng continues to advertise a network after it determines that the network is unreachable. The default is 120. |
timeout <15-259200> |
Configures the RIPng timeout interval. The default is 180. |
update <1–360> |
Configure the RIPng update timer. The update time is the time interval between RIPng updates. |
default-information <1–15> |
Configure the default route metric value. |
